[Gdal-dev] GDAL/MrSid-5 on Solaris 9
Sheykhet, Rostic
rsheykhet at sanz.com
Tue Jun 14 19:56:48 EDT 2005
Hi all,
I am trying to compile GDAL with MrSid support on Solaris 9 platform.
The LizardTech MrSid SDK version is 5.0.6.955 built for Solaris with GCC
3.2 compiler.
I am using GCC 3.4.x and getting problems during make (see below). The
xdr_??? Undefined symbols can be fixed by building with -lnsl library.
I am not able to resolve the other undefined symbols. Has anyone had
success building a similar setup?
Thanks a lot.
Rostic Sheykhet
make[1]: Entering directory `gdal/apps'
g++ gdalinfo.o \
/export/home/rsheykhe/sources/gdal/libgdal.a
-L/export/home/rsheykhe/sources/../binaries/solaris/mrsid/3rd-party/lib/
Release -lltiesdk
-L/export/home/rsheykhe/sources/../binaries/solaris/mrsid/lib/Release
-lltidsdk -lpthread
-L/export/home/rsheykhe/sources/../binaries/solaris/hdf/lib -lmfhdf -ldf
-lsz -ljpeg -lz -lm -ldl -L/export/home/rsheykhe/sources/kakadu/lib
-lkdu -lcryptopp -o gdalinfo
Undefined first referenced
symbol in file
std::allocator<char>::allocate(unsigned int, void
const*)/export/home/rsheykhe/sources/../binaries/solaris/mrsid/lib/Relea
se/libltidsdk.a(lt_stringUtils.o)
std::__default_alloc_template<true, 0>::allocate(unsigned
int)/export/home/rsheykhe/sources/../binaries/solaris/mrsid/lib/Release/
libltidsdk.a(lt_fileUtils.o)
xdr_float
/export/home/rsheykhe/sources/../binaries/solaris/hdf/lib/libmfhdf.a(put
get.o) (symbol belongs to implicit dependency /usr/lib/libnsl.so.1)
xdr_long
OGRSpatialReference::Validate()
/export/home/rsheykhe/sources/../binaries/solaris/mrsid/lib/Release/libl
tidsdk.a(lti_doqMetadata.o)
xdr_u_long
/export/home/rsheykhe/sources/../binaries/solaris/hdf/lib/libmfhdf.a(str
ing.o) (symbol belongs to implicit dependency /usr/lib/libnsl.so.1)
xdr_int
/export/home/rsheykhe/sources/../binaries/solaris/hdf/lib/libmfhdf.a(iar
ray.o) (symbol belongs to implicit dependency /usr/lib/libnsl.so.1)
xdr_double
xdr_enum
/export/home/rsheykhe/sources/../binaries/solaris/hdf/lib/libmfhdf.a(var
xdr_opaque
std::basic_string<char, std::char_traits<char>, std::allocator<char>
>::_Rep::_S_create(unsigned int, std::allocator<char>
const&)/export/home/rsheykhe/sources/../binaries/solaris/mrsid/lib/Relea
se/libltidsdk.a(MrSIDPasswordDelegate.o)
>::_S_empty_rep_storage/export/home/rsheykhe/sources/../binaries/solaris
/mrsid/lib/Release/libltidsdk.a(MrSIDPasswordDelegate.o)
std::__default_alloc_template<true, 0>::deallocate(void*, unsigned
OGRSpatialReference::exportToWkt(char**)
const/export/home/rsheykhe/sources/../binaries/solaris/mrsid/lib/Release
/libltidsdk.a(lti_doqMetadata.o)
>::_M_check(unsigned int)
/libltidsdk.a(lt_url.o)
ld: fatal: Symbol referencing errors. No output written to gdalinfo
collect2: ld returned 1 exit status
make: *** [gdalinfo] Error 1
