[Gdal-dev] Adding Projection to ECW files ?
Bill Binko
bill at binko.net
Sun Jun 19 13:59:37 EDT 2005
Hi everyone: I hope everyone enjoyed the conference. If anyone has time
to look at this, I'd really appreciate it. I really would like to be busy
making summary layers, but am stuck at this point.
Thanks
Bill
On Wed, 15 Jun 2005, Bill Binko wrote:
> Hi everyone,
> First, enjoy the conference: this can wait, but I wanted to ask while it
> was fresh. Wish I could join you.
> I have had some recent success with my raster project...
> 1) I have gotten GDAL & ECW to work on Linux (bug in ECW)
> 2) I have gotten gdaltindex to generate a tileindex of my DOQQs
> 3) I have gotten Mapserver to show my images (YAY) if I set the projection
> to UTM Zone 17N in the mapfile
> The problem is that the ECW files don't seem to have the UTM 17N
> associated with them in any metadata that GDAL reads. They come with
> .aux, .ecw, .ecw.xml, .ecw.aux.xml, and .html files for each image.
> Now, when I run gdalinfo on the file, I get this:
> [bill at fastcat ecw_rgb]$ gdalinfo dq4517ne.ecw
> Driver: ECW/ERMapper Compressed Wavelets
> Size is 6199, 7064
> Coordinate System is:
> LOCAL_CS["LOCAL",
> UNIT["Meter",1]]
> Origin = (397031.442000,3277747.800000)
> Pixel Size = (1.00000000,-1.00000000)
> Corner Coordinates:
> Upper Left ( 397031.442, 3277747.800)
> Lower Left ( 397031.442, 3270683.800)
> Upper Right ( 403230.442, 3277747.800)
> Lower Right ( 403230.442, 3270683.800)
> Center ( 400130.942, 3274215.800)
> Band 1 Block=6199x1 Type=Byte, ColorInterp=Red
> Overviews: arbitrary
> Band 2 Block=6199x1 Type=Byte, ColorInterp=Green
> Band 3 Block=6199x1 Type=Byte, ColorInterp=Blue
> So, I know that it has the boundary info, and I don't need separate .tfw
> (or equivalent). However, notice the LOCAL_CS -- it didn't find the
> projection information.
> Is there any way I can add this to the files? It should be the same for
> all of them.
> Without it, gdal_merge.py blows up, and I can't create summary images :(
> I know this is long winded, but can anyone help?
> Thanks
> Bill
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
