[Gdal-dev] CPLErrorV change to better support scriptland
Frank Warmerdam
fwarmerdam at gmail.com
Sun Jun 19 21:46:38 EDT 2005
On 6/19/05, Kevin Ruland <kruland at ku.edu> wrote:
> Frank,
> One of the things Shawn expressed dissatisfaction from was for some
> problems, gdal will abort() and the interpreter would go away very
> quickly. This of course, is not very nice behavour.
> The problem is very apparent in the NG swig code because I don't do any
> special parameter checking prior to calling the underlying method. So
> for example, say "out.tif" only contains one layer, then if I do this:
> f = gdal.Open( 'out.tif' )
> f.GetRasterBand(42)
> The underlying GDALDataset::GetRasterBand() gets the numer 42 with no
> prior checking. It rightfually decides this is a good time to issue a
> CPLError( CE_Fatal,....). The problem is CPLErrorV will call abort() if
> the error class is CE_Fatal. Bye bye python.
> I see that in the old bindings, you place extra checks in the script
> side for the parameters. This is not very amenable to supporting
> multiple bindings.
> Is there any way to remove this abort() entirely and leave it up to the
> application to decide if a problem is serious enough to abort? It just
> seems more polite but I don't understand what the implications would be.
Kevin,
I'm not really keen on removing the abort() for fatal errors, but
I do think that this particular error should be changed to just
a normal CE_Failure error intsead of a fatal error. Really the
only use I see currently for the fatal error is when CPLMalloc()
fails in an allocation.
I will change GDALDataset::GetRasterBand() to issue a
CE_Failure error and return NULL in case of an illegal input.
This can be then translated into an appropriate type of exception
in python and possibly other languages.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
