[Gdal-dev] Re: clipping raster using polygon?
Carlos A. Rueda carueda at ucdavis.edu
Fri Jun 24 16:31:24 EDT 2005
Bart,
I think you will find StarSpan (a tool based on GDAL/OGR/GEOS) very
useful for this operation:  http://starspan.casil.ucdavis.edu
carlos
Bart van den Eijnden wrote:
> Hi list,
> is it possible using GDAL to clip a raster using a polygon from eg a shapefile and have all the rest turn into NODATA values? If it is possible, how does it work?
> Thanks in advance.
> Best regards,
> Bart
> Syncera IT Solutions
> Postbus 270
> 2600 AG  DELFT
> tel.nr.: 015-7512436
> email: BEN at Syncera-ITSolutions.nl
