[Gdal-dev] is gdal support integrized sinusoidal projection which
used by some MODIS product?
Andrey Kiselev
dron at ak4719.spb.edu
Sun Jun 26 08:15:11 EDT 2005
On Sun, Jun 26, 2005 at 03:54:25PM +0800, Liangxu Wang wrote:
> I have looked the proj supported projection list, and known that
> sinusoidal projection are supported by proj, but the integrized
> sinusoidal projection are not mentioned in the list, which are used by
> some MODIS product, so if integrized sinusoidal projection are
> supported by GDAL?
GDAL works with projections via the PROJ.4 library, so the integerized
sinusoidal projection is not supported in the GDAL.
Best regards,
Andrey
Andrey V. Kiselev
Home phone: +7 812 5970603 ICQ# 26871517
