[Gdal-dev] GRASS/GDAL plugin issue
Frank Warmerdam
fwarmerdam at gmail.com
Thu Mar 3 14:29:57 EST 2005
On Thu, 3 Mar 2005 20:14:16 +0100, Markus Neteler <neteler at itc.it> wrote:
> Local problem or did anything change recently?
> I tried on two different machines where things were working so far.
Markus,
Sorry, I recently changed how plugins are searched for at the request
of a user. The default search location is now /usr/local/lib/gdal_plugins
instead of /usr/local/lib. This is to reduce the change of the wrong files
being loaded as plugins.
Try moving the gdal_GRASS.so you built.
I would add that if you define CPL_DEBUG to ON you will get
reports to stderr as plugins are loaded. This can be helpful to
debug plugin issues.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
