[Gdal-dev] Re: GRASS/GDAL plugin - floating point exception
Markus Neteler
neteler at itc.it
Thu Mar 10 18:10:07 EST 2005
On Thu, Mar 10, 2005 at 11:03:41PM +0100, Markus Neteler wrote:
> Frank,
> sorry to bother you again: after recompiling GRASS 6.1-CVS (yes, we
> published GRASS 6.0.0 today) from scratch (no library changes!)
> and a fresh GDAL from scratch, I again face new problems to use
> the gdal_GRASS.so. When I remove the plugin, everything runs well,
> when I compile/install the plugin, I get a Floating point exception.
A followup - I remember now the one change:
Today I have added systematic large file support (LFS) tests to
GRASS 6-CVS which is enabled by default. To be sure I just recompiled
with LFS disabled. Still the Floating point exception with
GDAL/GRASS plugin.
Any hint appreciated,
thanks
Markus
