[Gdal-dev] compilation problems on Slackware machine [update]
Frank Warmerdam
fwarmerdam at gmail.com
Tue Mar 15 03:02:50 EST 2005
On Mon, 14 Mar 2005 16:45:26 -0800, Dylan Beaudette
<dylan at iici.no-ip.org> wrote:
> 3. Errors returned from 'make'
> g++ -c -o thinplatespline.o thinplatespline.cpp
> thinplatespline.cpp: In member function `int VizGeorefSpline2D::solve()':
> thinplatespline.cpp:214: `FLT_MIN' undeclared (first use this function)
> thinplatespline.cpp:214: (Each undeclared identifier is reported only once for
> each function it appears in.)
> thinplatespline.cpp:214: `FLT_MAX' undeclared (first use this function)
> make[1]: *** [thinplatespline.o] Error 1
> make[1]: Leaving directory `/home/dylan/src/gdal-1.2.6/alg'
> make: *** [core-target] Error 2
Dylan,
The thinplatespline.cpp file attempts to include either float.h or
values.h if they are available (as determined by configure).
Does your gdal/port/cpl_config.h include #defines for
HAVE_FLOAT_H and/or HAVE_VALUES_H?
I have altered thinplatespline.cpp to include the following
optional definition after the attempt to include float.h and values.h:
#ifndef FLT_MAX
# define FLT_MAX 1e+37
# define FLT_MIN 1e-37
#endif
You can apply the same change to your local version.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
