[Gdal-dev] Lat/Lon to UTM conversion
Frank Warmerdam
fwarmerdam at gmail.com
Tue Mar 22 10:03:21 EST 2005
On Tue, 22 Mar 2005 15:27:54 +0100, Michele Sanges
<michele.sanges at otomelara.it> wrote:
> In order to convert a geographic coordinate (lat/lon - WGS84) to a projected coordinate (UTM - NAD83), I writted the following code:
> > OGRSpatialReference oUTM;
> > oUTM.SetWellKnownGeogCS( "NAD83" ); // the target reference system
> > OGRCoordinateTransformation *poTransform=OGRCreateCoordinateTransformation(&m_oSRS, &oUTM); // m_oSRS is the source reference system (WGS84)
> > if (poTransform == NULL)
> > return;
> > poTransform->Transform( 1, pfXproj, pfYproj );
> > delete poTransform;
> It don't works, the Transform function returns TRUE, but the coordinate (*pfXproj,*pfYproj) remain immutate.
> Moreover, how can I find the UTM zone?
Michele,
First of all, you haven't done anything to actually make oUTM
a UTM definition. So you are effectively just trying to convert
from m_oSRS (presumably WGS84) to NAD83 which to the system
are considered identical. Hence, no change.
I think you want something like:
oUTM.SetUTM( 11 );
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
