[Gdal-dev] Reading RPC
Frank Warmerdam
fwarmerdam at gmail.com
Mon Mar 28 22:57:34 EST 2005
On Fri, 25 Mar 2005 11:51:02 -0800, Peng Gao <pgao at esri.com> wrote:
> If I have an image with RPC (e.g. a NITF image from Space Imaging), how do
> I read the RPC
> information via GDAL? Is there a function similar to Set/GetGCPs() for RPC?
Peng,
The RPC information is transported as Metadata text. You can use the
GDALExtractRPCInfo() function to extract the metadata and build it into
a GDALRPCInfo structure suitable for examination or use with the GDAL
RPC functions.
You could do something like this:
char **papszMD;
GDALRPCInfo sRPC;
papszMD = GDALGetMetadata(hSrcDS,"");
if( GDALExtractRPCInfo( papszMD, &sRPC ) )
printf( "Got RPC Info\n" );
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
