[Gdal-dev] ogr.py Intersect with wkbGeometryCollection
Frank Warmerdam fwarmerdam at gmail.com
Thu May 5 14:22:11 EDT 2005
On 5/5/05, Ryan, Adam <ARyan at co.linn.or.us> wrote:
> Hi,
> I tried to use Geometry.Intersect with a wkbGeometryCollection type Geometry
> and got hung.  Is this not permited?
Adam,
I am not aware of a problem with this, but then I doubt I have specifically
tried it.  Can you prepare a relatively simple example to trigger this
problem?
Best regards,
