[Gdal-dev] Possible bug: numeric file name and gcps
Frank Warmerdam
fwarmerdam at gmail.com
Mon May 9 10:30:35 EDT 2005
On 5/9/05, Asger Petersen <asger at jo-informatik.dk> wrote:
> Hi
> I grew some gray hair finding out, that you can´t have a numeric filename when you use gcps with gdal_translate.
> This works:
> gdal_translate -of JP2KAK -gcp 0 0 702530.030 6172016.512 ht200414_06_7631.ecw ht200414_06_7631gcp.jp2
> This doesn't work:
> gdal_translate -of JP2KAK -gcp 0 0 702530.030 6172016.512 200414_06_7631.ecw 200414_06_7631gcp.jp2
> If you don't use gcps, there are no problems with numeric filenames. So this also works:
> gdal_translate -of JP2KAK 200414_06_7631.ecw 200414_06_7631gcp.jp2
Asger,
The problem is that there is an optional elevation argument in the
-gcp switch. The usage message should look like this (now updated):
[-gcp pixel line easting northing [elevation]]*
In order to determine if an elevation is supplied, the program tries
to read a numeric value from the argument. If it gets a non-zero
value it treats it as elevation.
I appologise for the needless misery this hackey approach has
caused you.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
