[Gdal-dev] Option to write ulxmap, ulymap, xdim, ydim to Ehdr format?
Brent Fraser bfraser at geoanalytic.com
Mon May 9 12:40:14 EDT 2005
Frank,
  I'll file an enhancement request.  It's low priority for now...
Thanks!
Brent
> ----- Original Message -----
> From: "Frank Warmerdam" <fwarmerdam at gmail.com>
> To: "Brent Fraser" <bfraser at geoanalytic.com>
> Cc: "GDAL Dev" <gdal-dev at remotesensing.org>
> Sent: Monday, May 09, 2005 10:24 AM
> Subject: Re: [Gdal-dev] Option to write ulxmap,ulymap,xdim,ydim to Ehdr
format?
> On 5/9/05, Brent Fraser <bfraser at geoanalytic.com> wrote:
> > Frank,
> >   Is there a command line option to have gdal_translate write ulxmap,
> > ulymap, xdim, ydim to the .hdr file of the Ehdr format?
> Brent,
> The gdal_translate command has a -a_ullr switch for setting
> the corners.  That is only in recent versions of GDAL.  Is that
> what you want?
> Hmm, on review, it seems the EHdr writer never writes out
> geolocation information.  I guess that is the problem you are
> running into? This is due to a very incomplete EHdr driver
> implementation.  You could submit an enhancement request,
> but unless it is a pressing need I am unlikely to implement it
> in the near term.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
