[Gdal-dev] WKT files out of date?
Kenneth Melero kmelero at sanz.com
Wed May 18 18:41:07 EDT 2005
Chris,
I wonder if this is related to the same issue I found the other day when I
was opening a GDAL generated Alber file in ERDAS and the "image information"
window reposnded that the code was invalid.
Actually I owe Frank a sample file...sorry Frank, I'll get that to you
soon...I was having trouble with my ERDAS.
-Ken
-----Original Message-----
[mailto:gdal-dev-bounces at xserve.flids.com] On Behalf Of Chris Hodgson
Sent: Wednesday, May 18, 2005 5:05 PM
To: gdal-dev
Subject: [Gdal-dev] WKT files out of date?
I was working with some gdal code and ran into an issue that the epsg
code 3005 (BC Albers) isn't in the ogr .wkt files and thus my
OGRSpatialReference code wasn't working as I expected... AFAICT, it's in
the latest proj.4 epsg file, but not in the gdal cvs .wkt files. I'm
surprised it's missing from gdal/ogr... actually, I thought gdal/ogr
used the proj definition file, until I stated investigating this and
found otherwise.
I only know about 3005 because it's a relatively new standard to my
knowledge (should replace 42102 which was previously in common use for
BC Albers) - so there may be others. Frank, don't you have these
generated from the same source files or something?
Anyways, I know I can just add it in to my files myself, but I wanted to
let you know.
Chris
Gdal-dev mailing list
Gdal-dev at xserve.flids.com http://xserve.flids.com/mailman/listinfo/gdal-dev
