[Gdal-dev] gdalwarp on CADRG / gltp: maps
Frank Warmerdam
fwarmerdam at gmail.com
Fri May 20 12:54:34 EDT 2005
On 5/20/05, Leibold, David <leibold at lsec.dnd.ca> wrote:
> Also tried pre-processing with gdal_translate - even trying -b switches to try different image bands than #4 Alpha. Still got black maps.
David,
I think the first step is to get gdal_translate working on the dataset.
If that isn't working, then the issue is likely a problem with the ADRG
driver in OGDI (or possibly the GDAL OGDI driver).
To be honest I get confused about this to. I tried it out with a
1:1M CADRG dataset I have here. When I do a gdalinfo on the dataset
I get alot of subdatasets:
Subdatasets:
SUBDATASET_1_NAME=gltp:/rpf/gdal/usr2/data/rpf/cadrg1M/rpf:"1:50K at 1@CADRG at DMAAC@3":Matrix
SUBDATASET_1_DESC=1:50K at 1@CADRG at DMAAC@3 as Matrix
SUBDATASET_2_NAME=gltp:/rpf/gdal/usr2/data/rpf/cadrg1M/rpf:"1:50K at 2@CADRG at DMAAC@4":Matrix
SUBDATASET_2_DESC=1:50K at 2@CADRG at DMAAC@4 as Matrix
SUBDATASET_3_NAME=gltp:/rpf/gdal/usr2/data/rpf/cadrg1M/rpf:"1:1M at 1@CADRG at DMAAC@5":Matrix
SUBDATASET_3_DESC=1:1M at 1@CADRG at DMAAC@5 as Matrix
SUBDATASET_4_NAME=gltp:/rpf/gdal/usr2/data/rpf/cadrg1M/rpf:"1:1M at 2@CADRG at DMAAC@6":Matrix
SUBDATASET_4_DESC=1:1M at 2@CADRG at DMAAC@6 as Matrix
SUBDATASET_5_NAME=gltp:/rpf/gdal/usr2/data/rpf/cadrg1M/rpf:"1:250K at 1@CADRG at DMAAC@7":Matrix
SUBDATASET_5_DESC=1:250K at 1@CADRG at DMAAC@7 as Matrix
SUBDATASET_6_NAME=gltp:/rpf/gdal/usr2/data/rpf/cadrg1M/rpf:"1:250K at 2@CADRG at DMAAC@8":Matrix
SUBDATASET_6_DESC=1:250K at 2@CADRG at DMAAC@8 as Matrix
SUBDATASET_7_NAME=gltp:/rpf/gdal/usr2/data/rpf/cadrg1M/rpf:"1:50K at 1@CADRG at DMAAC@3":Image
SUBDATASET_7_DESC=1:50K at 1@CADRG at DMAAC@3 as Image
SUBDATASET_8_NAME=gltp:/rpf/gdal/usr2/data/rpf/cadrg1M/rpf:"1:50K at 2@CADRG at DMAAC@4":Image
SUBDATASET_8_DESC=1:50K at 2@CADRG at DMAAC@4 as Image
SUBDATASET_9_NAME=gltp:/rpf/gdal/usr2/data/rpf/cadrg1M/rpf:"1:1M at 1@CADRG at DMAAC@5":Image
SUBDATASET_9_DESC=1:1M at 1@CADRG at DMAAC@5 as Image
SUBDATASET_10_NAME=gltp:/rpf/gdal/usr2/data/rpf/cadrg1M/rpf:"1:1M at 2@CADRG at DMAAC@6":Image
SUBDATASET_10_DESC=1:1M at 2@CADRG at DMAAC@6 as Image
SUBDATASET_11_NAME=gltp:/rpf/gdal/usr2/data/rpf/cadrg1M/rpf:"1:250K at 1@CADRG at DMAAC@7":Image
SUBDATASET_11_DESC=1:250K at 1@CADRG at DMAAC@7 as Image
SUBDATASET_12_NAME=gltp:/rpf/gdal/usr2/data/rpf/cadrg1M/rpf:"1:250K at 2@CADRG at DMAAC@8":Image
SUBDATASET_12_DESC=1:250K at 2@CADRG at DMAAC@8 as Image
I tried accessing these individual subdatasets, and it seems the first
two were just all black at "full res" and show a coarse grid at reduced
resolutions. But the third one was a respectible dataset. Furthermore,
the command:
gdalwarp -t_srs '+proj=utm +zone=12 +datum=WGS84'
'gltp:/rpf/gdal/usr2/data/rpf/cadrg1M/rpf:"1:1M at 1@CADRG at DMAAC@5":Matrix'
~/out.tif
Turn it into a decent reprojected image.
So, I think the key is to try each of the subdatasets and discover
which are "real" images of interest. Then warp those.
The good news is that it does work with CADRG in at least some
situations.
Good luck,
and watch the world go round - Rush | Geospatial Programmer for Rent
