[Gdal-dev] convert tiff file with world file into geotiff [solved]
Dylan Beaudette dylan at iici.no-ip.org
Fri May 27 15:03:38 EDT 2005
Tyler and others who replied,
Thanks for the very helpful tips on converting regular tiffs -> GeoTiff.
At the time I was missing the projection parameters for the data in question,
and thus could not really proceed any furthere. After receiving the proj
parameters (CA SPC: yuck!) I was able to re-project and convert all 600 tiff
files.
Thanks!
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
On Friday 27 May 2005 07:06 am, Tyler Mitchell wrote:
> Hi Dylan, did you figure something out re: your question?  I think you can
> use gdal_translate command line tool to convert a tiff with a world file
> into a geotiff - it should be the default output format in.  Or do you need
> to do the georeferencing from scratch too?  I've used gdal_translate's -gcp
> option quite a bit to assign georeferencing control points.  Let me know if
> you need more help.
> Tyler
> ----- Original Message -----
> From: Dylan Beaudette <dylan at iici.no-ip.org>
> Date: Tuesday, May 24, 2005 1:53 pm
> Subject: [Gdal-dev] convert tiff file with world file into geotiff
> > Hi,
> > I have a couple hundred tiff files that i would like to convert to
> > geotiff.
> > are there any simple ways to do this with gdal?
> > thanks!
