[Gdal-dev] /cvs/maptools/cvsroot/gdal/pymod/ng
Kevin Ruland
kruland at ku.edu
Wed Nov 2 11:26:57 EST 2005
Ken,
You are updating a very old snapshot. This directory had been removed
from the repository and the code placed instead in /gdal/swig/... If
you have no local changes you might be best served by blowing away your
current workspace and cvs co a new copy. If you have local changes you
need to preserve, then you might try:
cvs update -Pd
Which might get you past this problem. If it doesn't, and you're brave
you can edit gdal/pymod/CVS/Entries and remove the line for 'ng'. If
you're not that brave, then co a new copy into a new directory and
manually merge your changes into the new code base.
Kevin
Ken Sewell wrote:
>When doing a CVS update I get the following message:
>cvs update: Updating pymod/ng
>cvs update: cannot open directory /cvs/maptools/cvsroot/gdal/pymod/ng: No such file or directory
>cvs update: skipping directory pymod/ng
>Is this a CVS issue or something wrong with my copy?
>Ken Sewell Defense Research Associates
>Project Engineer 3915 Germany Lane, Suite 102
>937-656-4899 x3004 Beavercreek, Ohio 45431-1608
>sewell at dramail.com
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at lists.maptools.org
>http://lists.maptools.org/mailman/listinfo/gdal-dev
