[Gdal-dev] How can I get coordinate system and projection from
shape files?
lky
moon_inwell at 163.com
Fri Nov 4 03:30:24 EST 2005
Frank Warmerdam,
Thanks for your help.
I met another question about coordinate system and projection.
I read the data from the shapefile by OGRSFDriverRegistrar::Open() method , then I transform the data by OGRCoordinateTransformation::Transform() method. But the coordinate system and projection of the OGRDataSource is not changed at all.
How can I change the spatial reference?
The following is my program.
OGRDataSource* poDS = OGRSFDriverRegistrar::Open(sourcefile,FALSE); //Open Source Data
for (i=0;i<poDS->GetLayerCount();i++)
OGRLayer* poLayer = poDS->GetLayer(i); //Open Layer
OGRSpatialReference* pSourceSRS = poLayer->GetSpatialRef(); //Open Spatial Reference
OGRSpatialReference* pTargetSRS = pSourceSRS->Clone(); //Define target Spatial Reference
pTargetSRS->SetProjCS("TM");
pTargetSRS->SetTM(0,0,1,0,0);
OGRCoordinateTransformation* poCT = OGRCreateCoordinateTransformation(pSourceSRS,pTargetSRS); //Create Coordiante Transform
poLayer->ResetReading();
OGRFeature *poFeature;
while ((poFeature = poLayer->GetNextFeature()) != NULL) //Open Feature
poGeometry = poFeature->GetGeometryRef(); //Open Geometry
if (poGeometry !=NULL)
if (wkbFlatten(poGeometry->getGeometryType()) == wkbPoint) //point
OGRPoint *poPoint = (OGRPoint *) poGeometry; //Get coordiante
x = poPoint->getX();
y = poPoint->getY();
if (poCT == NULL || !poCT->Transform(1,&x,&y)) //transform x,y
err = 3;
return NULL;
poPoint->setX(x); //Set coordinate
poPoint->setY(y);
}//if
OGRFeature::DestroyFeature(poFeature); //deal feature
}//while -- feature loop
}//for -- layer loop
return poDS; //return data source
Best regards,
Kunyang Li
