[Gdal-dev] RE: OGR ODBC driver unable to read large text fields
properly
Tamas Szekeres
szekerest at gmail.com
Sat Nov 5 09:12:59 EST 2005
I have posted a bug report with a proposed solution at
http://bugzilla.remotesensing.org/show_bug.cgi?id=990
Tamas Szekeres
-----Original Message-----
From: Tamas Szekeres [mailto:szekerest at gmail.com]
Sent: Friday, November 04, 2005 11:26 PM
To: gdal-dev at lists.maptools.org
Subject: OGR ODBC driver unable to read large text fields properly
Hi list,
It seems that the OGR ODBC driver does not handle large text fields
(like WKT) properly. The OGR driver loads the data by 511 byte chunks
but leaves the terminating zero byte in the buffer after reading the
next chunk. It causes that only the first 511 byte will be considered
as the field value have been read.
Could anyone help to fix this problem.
Tamas Szekeres
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.1.362 / Virus Database: 267.12.8/161 - Release Date: 2005.11.03.
No virus found in this outgoing message.
