[Gdal-dev] why I can't use the method CSVGetField()?
lky moon_inwell at 163.com
Tue Nov 8 02:31:21 EST 2005
Hello,everyone:
    I use the method to read ellipsoid data from "data\ellipsoid.csv".I include the "cpl_csv.h",but there are so many build error after I include the header file.
dal.lib(cpl_csv.obj) : error LNK2005: _CSVFilename already defined in gdal_i.lib(gdal13.dll)
gdal.lib(cpl_csv.obj) : error LNK2005: _CSVFilename already defined in gdal_i.lib(gdal13.dll)
msvcprt.lib(MSVCP60.dll) : error LNK2005: "public: __thiscall std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >(class std::allocator<char>
const &)" (??0?$basic_string at DU?$char_traits at D@std@@V?$allocator at D@2@@std@@QAE at ABV?$allocator at D@1@@Z) already defined in main.obj
msvcprt.lib(MSVCP60.dll) : error LNK2005: "public: __thiscall std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >(class std::basic_string<cha
r,struct std::char_traits<char>,class std::allocator<char> > const &)" (??0?$basic_string at DU?$char_traits at D@std@@V?$allocator at D@2@@std@@QAE at ABV01@@Z) already defined in main.obj
msvcprt.lib(MSVCP60.dll) : error LNK2005: "public: __thiscall std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >(char const *,class std::all
ocator<char> const &)" (??0?$basic_string at DU?$char_traits at D@std@@V?$allocator at D@2@@std@@QAE at PBDABV?$allocator at D@1@@Z) already defined in main.obj
msvcprt.lib(MSVCP60.dll) : error LNK2005: "public: char const * __thiscall std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::c_str(void)const " (?c_str@?$basic_string at DU?$char_traits at D@std@@V?$allocator at D@2@@std@@QBE
PBDXZ) already defined in main.obj
msvcprt.lib(MSVCP60.dll) : error LNK2005: "public: class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > & __thiscall std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::operator=(clas
s std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &)" (??4?$basic_string at DU?$char_traits at D@std@@V?$allocator at D@2@@std@@QAEAAV01 at ABV01@@Z) already defined in main.obj
msvcprt.lib(MSVCP60.dll) : error LNK2005: "public: __thiscall std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::~basic_string<char,struct std::char_traits<char>,class std::allocator<char> >(void)" (??1?$basic_string@
DU?$char_traits at D@std@@V?$allocator at D@2@@std@@QAE at XZ) already defined in main.obj
msvcprt.lib(MSVCP60.dll) : error LNK2005: "public: unsigned int __thiscall std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::size(void)const " (?size@?$basic_string at DU?$char_traits at D@std@@V?$allocator at D@2@@std@@QBEIX
MSVCRT.lib(MSVCRT.dll) : error LNK2005: _fclose already defined in LIBCD.lib(fclose.obj)
MSVCRT.lib(MSVCRT.dll) : error LNK2005: _sprintf already defined in LIBCD.lib(sprintf.obj)
MSVCRT.lib(MSVCRT.dll) : error LNK2005: _strncpy already defined in LIBCD.lib(strncpy.obj)
MSVCRT.lib(MSVCRT.dll) : error LNK2005: _atof already defined in LIBCD.lib(atof.obj)
MSVCRT.lib(MSVCRT.dll) : error LNK2005: __snprintf already defined in LIBCD.lib(snprintf.obj)
MSVCRT.lib(MSVCRT.dll) : error LNK2005: _fflush already defined in LIBCD.lib(fflush.obj)
MSVCRT.lib(MSVCRT.dll) : error LNK2005: _calloc already defined in LIBCD.lib(dbgheap.obj)
MSVCRT.lib(MSVCRT.dll) : error LNK2005: _malloc already defined in LIBCD.lib(dbgheap.obj)
MSVCRT.lib(MSVCRT.dll) : error LNK2005: _realloc already defined in LIBCD.lib(dbgheap.obj)
MSVCRT.lib(MSVCRT.dll) : error LNK2005: _free already defined in LIBCD.lib(dbgheap.obj)
MSVCRT.lib(MSVCRT.dll) : error LNK2005: __vsnprintf already defined in LIBCD.lib(vsnprint.obj)
MSVCRT.lib(MSVCRT.dll) : error LNK2005: _abort already defined in LIBCD.lib(abort.obj)
gdal.lib(cpl_csv.obj) : warning LNK4006: _CSVFilename already defined in gdal_i.lib(gdal13.dll); second definition ignored
msvcprt.lib(MSVCP60.dll) : warning LNK4006: "public: __thiscall std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >(class std::allocator<char
> const &)" (??0?$basic_string at DU?$char_traits at D@std@@V?$allocator at D@2@@std@@QAE at ABV?$allocator at D@1@@Z) already defined in main.obj; second definition ignored
msvcprt.lib(MSVCP60.dll) : warning LNK4006: "public: __thiscall std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >(class std::basic_string<c
har,struct std::char_traits<char>,class std::allocator<char> > const &)" (??0?$basic_string at DU?$char_traits at D@std@@V?$allocator at D@2@@std@@QAE at ABV01@@Z) already defined in main.obj; second definition ignored
msvcprt.lib(MSVCP60.dll) : warning LNK4006: "public: __thiscall std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >(char const *,class std::a
llocator<char> const &)" (??0?$basic_string at DU?$char_traits at D@std@@V?$allocator at D@2@@std@@QAE at PBDABV?$allocator at D@1@@Z) already defined in main.obj; second definition ignored
msvcprt.lib(MSVCP60.dll) : warning LNK4006: "public: char const * __thiscall std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::c_str(void)const " (?c_str@?$basic_string at DU?$char_traits at D@std@@V?$allocator at D@2@@std@@Q
BEPBDXZ) already defined in main.obj; second definition ignored
msvcprt.lib(MSVCP60.dll) : warning LNK4006: "public: class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > & __thiscall std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::operator=(cl
ass std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &)" (??4?$basic_string at DU?$char_traits at D@std@@V?$allocator at D@2@@std@@QAEAAV01 at ABV01@@Z) already defined in main.obj; second definition ignored
msvcprt.lib(MSVCP60.dll) : warning LNK4006: "public: __thiscall std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::~basic_string<char,struct std::char_traits<char>,class std::allocator<char> >(void)" (??1?$basic_strin
g at DU?$char_traits at D@std@@V?$allocator at D@2@@std@@QAE at XZ) already defined in main.obj; second definition ignored
msvcprt.lib(MSVCP60.dll) : warning LNK4006: "public: unsigned int __thiscall std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::size(void)const " (?size@?$basic_string at DU?$char_traits at D@std@@V?$allocator at D@2@@std@@QBE
IXZ) already defined in main.obj; second definition ignored
MSVCRT.lib(MSVCRT.dll) : warning LNK4006: _fclose already defined in LIBCD.lib(fclose.obj); second definition ignored
MSVCRT.lib(MSVCRT.dll) : warning LNK4006: _sprintf already defined in LIBCD.lib(sprintf.obj); second definition ignored
MSVCRT.lib(MSVCRT.dll) : warning LNK4006: _strncpy already defined in LIBCD.lib(strncpy.obj); second definition ignored
MSVCRT.lib(MSVCRT.dll) : warning LNK4006: _atof already defined in LIBCD.lib(atof.obj); second definition ignored
MSVCRT.lib(MSVCRT.dll) : warning LNK4006: __snprintf already defined in LIBCD.lib(snprintf.obj); second definition ignored
MSVCRT.lib(MSVCRT.dll) : warning LNK4006: _fflush already defined in LIBCD.lib(fflush.obj); second definition ignored
MSVCRT.lib(MSVCRT.dll) : warning LNK4006: _calloc already defined in LIBCD.lib(dbgheap.obj); second definition ignored
MSVCRT.lib(MSVCRT.dll) : warning LNK4006: _malloc already defined in LIBCD.lib(dbgheap.obj); second definition ignored
MSVCRT.lib(MSVCRT.dll) : warning LNK4006: _realloc already defined in LIBCD.lib(dbgheap.obj); second definition ignored
MSVCRT.lib(MSVCRT.dll) : warning LNK4006: _free already defined in LIBCD.lib(dbgheap.obj); second definition ignored
MSVCRT.lib(MSVCRT.dll) : warning LNK4006: __vsnprintf already defined in LIBCD.lib(vsnprint.obj); second definition ignored
MSVCRT.lib(MSVCRT.dll) : warning LNK4006: _abort already defined in LIBCD.lib(abort.obj); second definition ignored
   Creating library Debug/gause.lib and object Debug/gause.exp
LINK : warning LNK4098: defaultlib "MSVCRT" conflicts with use of other libs; use /NODEFAULTLIB:library
Debug/gause.exe : fatal error LNK1169: one or more multiply defined symbols found
Error executing link.exe.
Creating browse info file...
so I have two questions:
1.Why I can't use the method CSVGetField()?
2.If I want to read the ellipsoid data from "data\ellipsoid.csv", how I can do?
Thanks a lot
Kunyang Li
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051108/3db1943d/attachment.html
