[Gdal-dev] [newbie] ogr projection or proj.4?
Tore Halset
halset at pvv.ntnu.no
Tue Nov 8 14:42:28 EST 2005
Hello.
I am creating a simple map viewer using gdal and ogr. I have also
created another vector layer that does not use gdal or ogr.
I am currently using proj.4 for my projection class, but consider
moving to ogr. I guess ogr projection are build upon proj.4. Will
things be less complicated if I use ogr projection? And will I get
more features that I might need? What do you gurus think?
- Tore.
