[Gdal-dev] Compiling with VC++8
Tue Nov 8 16:59:04 EST 2005
On 11/8/05, Charles F. I. Savage <cfis at interserv.com> wrote:
> Two minor changes are needed to compile gdal with VC++ 8 (ie., VC 2005).
> The strstr method now returns either a char* or const char* depending
> on the parameters sent to it.  See
> http://msdn2.microsoft.com/en-us/library/z9da80kz.aspx for more info.
> Patch is below, I'll apply unless someone says otherwise.
Charlie,
I'll apply it to the upstream MITAB source tree.
Best regards,
