[Gdal-dev] Java library for reading ESRI shapefiles?
Ethan Alpert
ealpert at digitalglobe.com
Tue Nov 8 17:19:40 EST 2005
I know you can do this with GeoTools but like all java you get a bunch
of stuff you don't need.
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Tim Beckmann
Sent: Tuesday, November 08, 2005 2:42 PM
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] Java library for reading ESRI shapefiles?
Does anyone know of a freely available Java library for reading ESRI
shapefiles? The gdal ogr and shapelib code has been great in the past,
but now I have a need to read ESRI shapefiles directly from a Java
applet.
Thanks
Tim
Tim Beckmann
Software Project Lead
Science Applications International Corporation (SAIC) Contractor to the
USGS/EROS Sioux Falls, SD 57198
605-594-2521 Phone
605-594-6940 Fax
tbeckman at usgs.gov
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
