[Gdal-dev] Java library for reading ESRI shapefiles?
Pete Nagy Peter.Nagy at vexcel.com
Tue Nov 8 17:37:23 EST 2005
I'd like to see gdal wrapped in java.  How hard would it be to swig it?
The python wrappers were initially created with an old version of swig,
right?
-> Pete
Pete Nagy                                        tel: (303) 583-0248
Vexcel Corporation                               fax: (303) 583-0246
http://www.vexcel.com                           home: (303) 823-2336
On Tue, 8 Nov 2005, Frank Warmerdam wrote:
> On 11/8/05, Tim Beckmann <tbeckman at usgs.gov> wrote:
> > Does anyone know of a freely available Java library for reading ESRI
> > shapefiles?  The gdal ogr and shapelib code has been great in the past,
> > but now I have a need to read ESRI shapefiles directly from a Java applet.
> Tim,
> I would suggest you check GeoTools.  There are definately a number
> of Shapefile implementations in Java out there though some may
> not be easily seperable.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
