[Gdal-dev] Java library for reading ESRI shapefiles?
Tim Beckmann tbeckman at usgs.gov
Tue Nov 8 17:40:00 EST 2005
Thanks all for the quick responses.  I'll have to review the options to
see which will work the best for our applet environment.
Tim Beckmann
Software Project Lead
Science Applications International Corporation (SAIC)
Contractor to the USGS/EROS
Sioux Falls, SD 57198
605-594-2521    Phone
605-594-6940    Fax
Frank Warmerdam <warmerdam at pobox.com>
Sent by: fwarmerdam at gmail.com
11/08/2005 04:10 PM
To
Tim Beckmann <tbeckman at usgs.gov>
cc
gdal-dev at lists.maptools.org
Subject
Re: [Gdal-dev] Java library for reading ESRI shapefiles?
On 11/8/05, Tim Beckmann <tbeckman at usgs.gov> wrote:
> Does anyone know of a freely available Java library for reading ESRI
> shapefiles?  The gdal ogr and shapelib code has been great in the past,
> but now I have a need to read ESRI shapefiles directly from a Java
applet.
Tim,
I would suggest you check GeoTools.  There are definately a number
of Shapefile implementations in Java out there though some may
not be easily seperable.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
