[Gdal-dev] Different compiler problem
Jonathan Greenberg
jgreenberg at arc.nasa.gov
Thu Nov 10 17:30:07 EST 2005
With this config call:
./configure --prefix=/sw --with-local=/sw --without-python
--with-geotiff=internal --with-hdf4=no --without-ogdi --without-pg
--without-mysql --with-geos --with-static-proj4=/sw --with-threads
--with-libtiff=/sw --with-geotiff=internal --with-jpeg=/sw --with-gif=/sw
--with-png=/sw
I'm getting this failure:
g++-3.3 -DHAVE_MITAB -Wall -Os -I/sw/include -I../port -I../gcore -I../alg
-I../ogr -I../ogr/ogrsf_frmts -Os -I/sw/include -I/sw/include -I/sw/include
-I../port -I/sw -I/sw/include -I/sw -I/sw/include -I/sw/include -I/sw
-I/sw/include -c gdalopeninfo.cpp -fno-common -DPIC -o .libs/gdalopeninfo.o
In file included from gdal_priv.h:256,
from gdalopeninfo.cpp:40:
gdal.h:155: error: syntax error before `(' token
gdal.h:156: error: syntax error before `(' token
gdal.h:157: error: syntax error before `(' token
gdal.h:158: error: syntax error before `(' token
gdal.h:159: error: syntax error before `(' token
gdal.h:239: error: parse error before `*' token
gdal.h:240: error: syntax error before `(' token
gdal.h:241: error: syntax error before `(' token
gdal.h:242: error: syntax error before `(' token
gdal.h:243: error: syntax error before `(' token
gdal.h:245: error: syntax error before `(' token
gdal.h:269: error: syntax error before `(' token
gdal.h:271: error: syntax error before `(' token
gdal.h:275: error: syntax error before `(' token
gdal.h:279: error: syntax error before `(' token
gdal.h:280: error: syntax error before `(' token
gdal.h:281: error: syntax error before `(' token
gdal.h:283: error: syntax error before `(' token
gdal.h:284: error: syntax error before `(' token
gdal.h:285: error: syntax error before `(' token
gdal.h:286: error: syntax error before `(' token
gdal.h:287: error: syntax error before `(' token
gdal.h:288: error: syntax error before `(' token
gdal.h:289: error: syntax error before `(' token
gdal.h:292: error: syntax error before `(' token
gdal.h:293: error: syntax error before `(' token
gdal.h:294: error: syntax error before `(' token
gdal.h:295: error: syntax error before `(' token
gdal.h:325: error: syntax error before `(' token
gdal.h:326: error: syntax error before `(' token
gdal.h:327: error: syntax error before `(' token
gdal.h:330: error: syntax error before `(' token
gdal.h:333: error: syntax error before `(' token
gdal.h:335: error: syntax error before `(' token
gdal.h:342: error: syntax error before `(' token
gdal.h:343: error: syntax error before `(' token
gdal.h:346: error: syntax error before `(' token
gdal.h:348: error: syntax error before `(' token
gdal.h:350: error: syntax error before `(' token
gdal.h:351: error: syntax error before `(' token
gdal.h:357: error: syntax error before `(' token
gdal.h:358: error: syntax error before `(' token
gdal.h:359: error: syntax error before `(' token
gdal.h:360: error: syntax error before `(' token
gdal.h:361: error: syntax error before `(' token
gdal.h:362: error: syntax error before `(' token
gdal.h:364: error: syntax error before `(' token
gdal.h:367: error: syntax error before `(' token
gdal.h:374: error: syntax error before `(' token
gdal.h:379: error: syntax error before `(' token
gdal.h:380: error: syntax error before `(' token
gdal.h:381: error: syntax error before `(' token
gdal.h:382: error: syntax error before `(' token
gdal.h:384: error: syntax error before `(' token
gdal.h:385: error: syntax error before `(' token
gdal.h:386: error: syntax error before `(' token
gdal.h:387: error: syntax error before `(' token
gdal.h:390: error: syntax error before `(' token
gdal.h:391: error: syntax error before `(' token
gdal.h:392: error: syntax error before `(' token
gdal.h:395: error: syntax error before `(' token
gdal.h:397: error: syntax error before `(' token
gdal.h:398: error: syntax error before `(' token
gdal.h:399: error: syntax error before `(' token
gdal.h:405: error: syntax error before `(' token
gdal.h:407: error: syntax error before `(' token
gdal.h:409: error: syntax error before `(' token
gdal.h:414: error: syntax error before `(' token
gdal.h:418: error: syntax error before `(' token
gdal.h:419: error: syntax error before `(' token
gdal.h:420: error: syntax error before `(' token
gdal.h:421: error: syntax error before `(' token
gdal.h:422: error: syntax error before `(' token
gdal.h:423: error: syntax error before `(' token
gdal.h:424: error: syntax error before `(' token
gdal.h:425: error: syntax error before `(' token
gdal.h:428: error: syntax error before `(' token
gdal.h:430: error: syntax error before `(' token
gdal.h:431: error: syntax error before `(' token
gdal.h:432: error: syntax error before `(' token
gdal.h:433: error: syntax error before `(' token
gdal.h:434: error: syntax error before `(' token
gdal.h:435: error: syntax error before `(' token
gdal.h:436: error: syntax error before `(' token
gdal.h:437: error: syntax error before `(' token
gdal.h:438: error: syntax error before `(' token
gdal.h:439: error: syntax error before `(' token
gdal.h:440: error: syntax error before `(' token
gdal.h:441: error: syntax error before `(' token
gdal.h:442: error: syntax error before `(' token
gdal.h:445: error: syntax error before `(' token
gdal.h:446: error: syntax error before `(' token
gdal.h:447: error: syntax error before `(' token
gdal.h:448: error: syntax error before `(' token
gdal.h:449: error: syntax error before `(' token
gdal.h:451: error: syntax error before `(' token
gdal.h:453: error: syntax error before `(' token
gdal.h:454: error: syntax error before `(' token
gdal.h:460: error: syntax error before `(' token
gdal.h:466: error: syntax error before `(' token
gdal.h:470: error: syntax error before `(' token
gdal.h:472: error: syntax error before `(' token
gdal.h:473: error: syntax error before `(' token
gdal.h:476: error: syntax error before `(' token
gdal.h:483: error: type specifier omitted for parameter `GDALProgressFunc'
gdal.h:483: error: parse error before `,' token
gdal.h:486: error: syntax error before `(' token
gdal.h:488: error: syntax error before `(' token
gdal.h:494: error: syntax error before `(' token
gdal.h:496: error: syntax error before `(' token
gdal.h:499: error: syntax error before `(' token
gdal.h:503: error: syntax error before `(' token
gdal.h:506: error: syntax error before `(' token
gdal.h:509: error: syntax error before `(' token
gdal.h:513: error: syntax error before `(' token
gdal.h:514: error: syntax error before `(' token
gdal.h:515: error: syntax error before `(' token
gdal.h:517: error: syntax error before `(' token
gdal.h:544: error: syntax error before `(' token
gdal.h:565: error: syntax error before `(' token
gdal.h:566: error: syntax error before `(' token
gdal.h:567: error: syntax error before `(' token
gdal.h:568: error: syntax error before `(' token
gdal.h:569: error: syntax error before `(' token
gdal.h:570: error: syntax error before `(' token
gdal.h:571: error: syntax error before `(' token
gdal.h:572: error: syntax error before `(' token
gdal.h:607: error: syntax error before `(' token
gdal.h:608: error: syntax error before `(' token
gdal.h:611: error: syntax error before `(' token
gdal.h:613: error: syntax error before `(' token
gdal.h:615: error: syntax error before `(' token
gdal.h:617: error: syntax error before `(' token
gdal.h:620: error: syntax error before `(' token
gdal.h:622: error: syntax error before `(' token
gdal.h:624: error: syntax error before `(' token
gdal.h:626: error: syntax error before `(' token
gdal.h:628: error: syntax error before `(' token
gdal.h:631: error: syntax error before `(' token
gdal.h:633: error: syntax error before `(' token
gdal.h:635: error: syntax error before `(' token
gdal.h:637: error: syntax error before `(' token
gdal.h:639: error: syntax error before `(' token
gdal.h:643: error: syntax error before `(' token
gdal.h:645: error: syntax error before `(' token
gdal.h:647: error: syntax error before `(' token
gdal.h:649: error: syntax error before `(' token
gdal.h:652: error: syntax error before `(' token
gdal.h:658: error: syntax error before `(' token
gdal.h:659: error: syntax error before `(' token
gdal.h:660: error: syntax error before `(' token
gdal.h:661: error: syntax error before `(' token
In file included from gdalopeninfo.cpp:40:
gdal_priv.h:282: error: 'CPLString' is used as a type, but is not defined as
a
type.
gdal_priv.h:332: error: type specifier omitted for parameter
`GDALProgressFunc'
gdal_priv.h:332: error: parse error before `,' token
gdal_priv.h:344: error: `CPL_STDCALL' is neither function nor member
function;
cannot be declared friend
gdal_priv.h:344: error: parse error before `(' token
gdal_priv.h:345: error: `CPL_STDCALL' is neither function nor member
function;
gdal_priv.h:345: error: declaration of `void*GDALDataset::CPL_STDCALL'
gdal_priv.h:344: error: conflicts with previous declaration `
gdal_priv.h:345: error: parse error before `(' token
gdal_priv.h:370: error: type specifier omitted for parameter
`GDALProgressFunc'
gdal_priv.h:431: error: type specifier omitted for parameter
`GDALProgressFunc'
gdal_priv.h:345: error: duplicate member `GDALDataset::CPL_STDCALL'
gdal_priv.h:623: error: type specifier omitted for parameter
`GDALProgressFunc'
gdal_priv.h:632: error: type specifier omitted for parameter
`GDALProgressFunc'
gdal_priv.h:637: error: type specifier omitted for parameter
`GDALProgressFunc'
gdal_priv.h:705: error: type specifier omitted for parameter
`GDALProgressFunc'
gdal_priv.h:705: error: parse error before `,' token
gdal_priv.h:724: error: type specifier omitted for parameter
`GDALProgressFunc'
gdal_priv.h:724: error: parse error before `,' token
gdal_priv.h:785: error: type specifier omitted for parameter
`GDALProgressFunc'
gdal_priv.h:785: error: parse error before `,' token
gdal_priv.h:792: error: type specifier omitted for parameter
`GDALProgressFunc'
gdal_priv.h:792: error: parse error before `,' token
gdal_priv.h:799: error: type specifier omitted for parameter
`GDALProgressFunc'
gdal_priv.h:799: error: parse error before `,' token
gdal_priv.h:804: error: type specifier omitted for parameter
`GDALProgressFunc'
make[1]: *** [gdalopeninfo.o] Error 1
make: *** [core-target] Error 2
### execution of /var/tmp/tmp.1.Rcn0Jn failed, exit code 2
Removing build lock...
/sw/bin/dpkg-lockwait -r fink-buildlock-gdal-1.3.1-1
(Reading database ... 70736 files and directories currently installed.)
Removing fink-buildlock-gdal-1.3.1-1 ...
Failed: phase compiling: gdal-1.3.1-1 failed
Jonathan A. Greenberg, PhD
NRC Research Associate
NASA Ames Research Center
MS 242-4
Moffett Field, CA 94035-1000
Office: 650-604-5896
Cell: 415-794-5043
AIM: jgrn307
MSN: jgrn307 at hotmail.com
