[Gdal-dev] [solved] Re: ogr2ogr question
Bart van den Eijnden bartvde at xs4all.nl
Fri Nov 11 08:28:53 EST 2005
The second time I tried it comes back normally. I was probably too
impatient at the time, and the spatial index creation probably took
quite long :-)
Sorry for the confusion.
Best regards,
Bart
Bart van den Eijnden wrote:
> Hi list,
> I am using ogr2ogr as a tool to load data into Oracle Spatial and I
> want to do this in batch.
> Did anybody ever experience that the ogr2ogr command does not finish
> (i.e. give back focus to the DOS prompt), although all features are
> already in the database and the spatial index has been created? I had
> to terminate the batch job myself. The table has almost a million
> records. A smaller table worked without any problems. What could be
> the problem?
> Thanks in advance.
> Best regards,
> Bart
