[Gdal-dev] RE: Reading JPEG2000 JPC and J2K
Peng Gao
pgao at esri.com
Fri Nov 11 09:47:45 EST 2005
> -----Original Message-----
> From: Peng Gao
> Sent: Friday, November 11, 2005 6:30 AM
> To: gdal-dev at lists.maptools.org
> Subject: Reading JPEG2000 JPC and J2K
> I got some images with .jpc and .j2k extensions. Is there any
> way I can read them using GDAL?
> I renamed them to .jp2, and it didn't work. I am using Kakadu codec.
> Gao, Peng
I read the doc on JP2KAK driver again, and it should support JPC. The
problem could be the image I have. Attached is a problem jpc image.
Gao, Peng
Type: application/octet-stream
Desc: input.jpc
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051111/31b6ff95/input.obj
