[Gdal-dev] Use of individual drivers
Kor de Jong
k.dejong at geo.uu.nl
Fri Nov 11 14:10:43 EST 2005
Hi Frank,
Op vrijdag 11 november 2005 15:58, schreef Frank Warmerdam:
> On 11/11/05, Kor de Jong <k.dejong at geo.uu.nl> wrote:
> > In short, is it possible to get around the high level GDAL functions and
> > use the individual GDAL drivers directly? If not, does the design of GDAL
> > allow it to be changed to allow such use?
> I can imagine a couple solutions.
> 1) I could implement a GDALOpenWithDriver() with an
> extra argument that is the driver that should be used (as
> opposed to scanling the GDALDriverManager list).
This would be a pretty clean solution I guess, also because GDALOpen can use
this function too.
> 2) You could manipulate the GDALDriverManager ensuring
> that only the one driver at a time is registered. That way
> only that driver would be used by GDALOpen().
Yes, I think I can get this to work. It is a bit of a hassle to manipulate the
manager for each format driver, but if I have to I will do it like this.
> If (2) is fine for you, then no core changes are required. If not,
> then I would be willing to implement option 1, which I have
> occationally wished existed for other reasons.
Given your last remark I opt for (1) and I am willing to help ofcourse. As far
as I can see this would mean creating a new function whose body is similar to
GDALOpen, except for the looping over all drivers and making this function a
friend of GDALDataset.
Thanks for your help Frank.
Kor
Kor de Jong, k.dejong at geo.uu.nl
Fysische Geografie, Geowetenschappen, Universiteit Utrecht
