[Gdal-dev] Error compiling on Solaris 10 with GeoExpress SDK
Sheykhet, Rostic
rsheykhet at sanz.com
Tue Nov 15 19:17:53 EST 2005
Chris,
At least on Linux, there were separate DSDK builds for different GCC
compiler versions. Make sure that you've downloaded the right one. I
do not have a login on the site so I cannot verify that the "right"
version is available for download. You might have to ask them to post
one.
Rostic
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Chris Garrard
Sent: Tuesday, November 15, 2005 4:20 PM
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] Error compiling on Solaris 10 with GeoExpress SDK
Hello,
I'm trying to compile GDAL 1.3.1 on Solaris 10. It works great until I
try and compile in the GeoExpress SDK. The LizardTech downloads page
says it works with Solaris 8 and 9 and gcc 3.2.3. I'm using gcc 3.4.4.
Has anyone else tried this, or know if the problem is with my compiler
version or the OS version?
Here is the error I'm getting:
g++ ogrinfo.o -o .libs/ogrinfo ../.libs/libgdal.so -L/opt/csw/src
/opt/csw/lib/libproj.so -L/opt/csw/extras/Geo_DSDK-5.0.6.955/lib/Release
-L/opt/csw/extras/Geo_DSDK-5.0.6.955/3rd-party/lib/Release -lltidsdk
-lpthread -lltikdu /opt/csw/lib/libjasper.so -ljpeg -lrt -ldl
-L/opt/csw/lib -L/opt/csw/mysql4/lib/mysql
/opt/csw/mysql4/lib/mysql/libmysqlclient.so -lz -lposix4 -lc -lgen
-lsocket -lnsl -lssl -lcrypto -Wl,-R -Wl,/opt/csw/lib -Wl,-R
-Wl,/opt/csw/mysql4/lib/mysql
Undefined first referenced
symbol in file
std::__default_alloc_template<true, 0>::deallocate(void*, unsigned
int)../.libs/libgdal.so
std::basic_string<char, std::char_traits<char>, std::allocator<char>
>::_M_check(unsigned int) const../.libs/libgdal.so
>::_S_empty_rep_storage../.libs/libgdal.so
std::allocator<char>::allocate(unsigned int, void
const*)../.libs/libgdal.so
std::__default_alloc_template<true, 0>::allocate(unsigned
>::_Rep::_S_create(unsigned int, std::allocator<char>
const&)../.libs/libgdal.so
ld: fatal: Symbol referencing errors. No output written to .libs/ogrinfo
collect2: ld returned 1 exit status
gmake[1]: *** [ogrinfo] Error 1
gmake[1]: Leaving directory `/opt/csw/extras/gdal-1.3.1/ogr'
gmake: *** [ogr-apps] Error 2
Thanks,
Chris
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
