[Gdal-dev] Gdal compilation problems in Solaris 8
Juan Mari Celihueta
jmcm at euskalnet.net
Wed Nov 16 01:14:34 EST 2005
So, nobody had problems compiling gdal 1.3.1 under Solaris 8? Is gdal
1.3.1 tested under this platform?
Regards.
Juan M.
Frank Warmerdam escribió:
>On 11/14/05, Juan Mari Celihueta <jmcm at euskalnet.net> wrote:
>>I continue with the same problem. I added the prefix you indicated, and
>>I also tried as root, but I get exactly the same error message.
>>I hope someone can help me.
>Juan,
>It seems you are running into some funky problem with
>the linker and/or libtool's handling of shared libraries. I
>have no idea how to fix things.
>Best regards,
>I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush | Geospatial Programmer for Rent
