[Gdal-dev] Arc Binary Coverages
Ari Jolma
ari.jolma at tkk.fi
Wed Nov 16 07:29:18 EST 2005
Craig Miller kirjoitti:
> I'm not sure about librarian, but image catalog data is stored in the info
>database. Infolib allows you to work with info databases directly and has
>been around since around 1990. I'm not sure of the status of it these days
>though.
I found this: http://www.epa.gov/Region10/dbf2info.html#contents by
this:
http://www.intevation.de/pipermail/freegis-list/2001-February/000268.html
but the links to the actual software are dead. Is the image catalog data
vital somehow? In some info-dirs of our data I see a lot of *.nit and
*.dat files but some of those are read by ogr?
Ari
>--Craig
>-----Original Message-----
>From: Ari Jolma [mailto:ari.jolma at tkk.fi]
>Sent: Tuesday, November 15, 2005 11:43 PM
>To: Craig Miller
>Cc: 'Matthew Perry'; 'Gdal-Dev'
>Subject: Re: [Gdal-dev] Arc Binary Coverages
>Seems like the obvious solution is to write a new driver: "Arc/Info Binary
>Coverage B"?
>I have very little experience with a/i binary coverages. Is there any way
>(even non-ogr but non a/i) to read librarian and image catalog data now?
>Ari
>>Matt,
>>A coverage contains one data layer, along with different types of topology.
>>These would all continue to be accessible if the Workspace was
>>considered the datasource. They would all have the same name, but a
>>different type attribute. Perhaps we would have to append something to
>>the coverage name to make it clear since OGIS (and as a result OGR)
>>doesn't support as many types as the Arc Coverage model, but rather
>>maps some of the types to a simple feature. A name such as <layer>
>><type> would work. For example, "Streams (ARC)". This appears to be
>>more intuitive, informative, unique, and closer to the true name of the
>coverage that always using "ARC".
>>The workspace is also where the attribute database is stored and it
>>contains information such as Librarian data and Image Catalog data.
>>Right now, there is no way to add support for Librarian to the driver
>>(which is actually where I started looking at this).
>>I was thinking that regions will continue to be supported with a name
>>such as <layername> - <region> <type>. For example "Streams -
>>Lake_Wenatchee_Basin (region)"
>>I'm still pretty confident that the two data models map perfectly onto
>>each other with exception to the fact that OGIS/OGR have smaller set of
>>supported layer types. Naming conventions seems like an easy way to
>>work around this and still preserve the simple features nature of the OGR
>library.
>>--Craig
>>From: Matthew Perry [mailto:perrygeo at gmail.com]
>>Sent: Monday, November 14, 2005 2:52 PM
>>To: Craig Miller
>>Cc: Gdal-Dev
>>Craig,
>> There are good reasons to treat the coverage, rather than the
>>workspace, as the dataset. The biggest reason is that a coverage
>>contains multiple data layers (tics,lines, centroids, polygons or
>>points, etc). In addition ArcInfo's regions data model allows you to
>>store many spatially-related layers within a single coverage.
>>If the workspace were the dataset and the coverage were the layer,
>>there would be no way to get at the region layers (or tics, or any of
>>the other supporting spatial data) within the coverage.
>>I happen to work with regions occasionally so I'm very thankful for the
>>way OGR handles ArcInfo Coverages! ;-)
>>matt
>>On 11/14/05, Craig Miller <craig.miller at spatialminds.com> wrote:
>>>Is there a reason why the Arc Binary Coverage driver uses the Coverage
>>>directory instead of the Workspace that is traditionally used in Arc/Info?
>>>E.g. I would have expected to pass a directory to the workspace like
>>>/data/county and receive back a list of coverages in that workspace
>>>such
>>as:
>>>Lakes - Type:Polygon
>>>Lakes - Type:Point (Polygon Labels)
>>>Lakes - Type:Linestring (Polygon boundary with line topology built)
>>>Roads - Type:Linestring
>>>Etc.
>>>Instead it asks for a path to the coverage /data/county/lakes and
>>>returns layers named things such as ARC.
>>>_______________________________________________
>>>Gdal-dev mailing list
>>>Gdal-dev at lists.maptools.org
>>>http://lists.maptools.org/mailman/listinfo/gdal-dev
>>Matt Perry
>>http://www.perrygeo.net
>Prof. Ari Jolma
>Kartografia ja Geoinformatiikka / Cartography and Geoinformatics Teknillinen
>Korkeakoulu / Helsinki University of Technology POBox 1200, 02015 TKK,
>Finland
>Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
Prof. Ari Jolma
Teknillinen Korkeakoulu / Helsinki University of Technology
POBox 1200, 02015 TKK, Finland
