[Gdal-dev] problem merging 1 second data with gdal_merge.py
Wed Nov 16 13:31:53 EST 2005
Rich,
It seems the problem was roundoff related in
the initial computation of the output file size.
If you re-fetch the file it should have a round off fix.
  http://www.gdal.org/srctree/pymod/gdal_merge.py
Best regards,
