[Gdal-dev] Gdal compilation problems in Solaris 8
Juan Mari Celihueta
jmcm at euskalnet.net
Thu Nov 17 08:28:21 EST 2005
Hi, I have partially solved the compilation problems under Solaris 8,
but now I have found another one.
First, the problem that I had was related to the 'ld' command:
ld: fatal: relocations remain against allocatable but non-writable sections
collect2: ld returned 1 exit status
make[1]: *** [libgdal.la] Error 1
make[1]: Leaving directory `/home1/MAPSERVER/gdal-1.3.1'
make: *** [check-lib] Error 2
That was because 'make' used a wrong 'ld' although I had GNU ld in the
'PATH' variable (I guessed it seeing the ./configure process). I solved
it renaming the wrong 'ld'.
Second, the new compilation problem: During the compilation process,
after several minutes of hard process, I get the next error message:
.libs/libgdal.lax/libjasper.a/pgx_enc.o
.libs/libgdal.lax/libjasper.a/pnm_cod.o
.libs/libgdal.lax/libjasper.a/pnm_dec.o
.libs/libgdal.lax/libjasper.a/pnm_enc.o
.libs/libgdal.lax/libjasper.a/ras_cod.o
.libs/libgdal.lax/libjasper.a/ras_dec.o
.libs/libgdal.lax/libjasper.a/ras_enc.o
ranlib .libs/libgdal.a
rm -fr .libs/libgdal.lax
creating libgdal.la
(cd .libs && rm -f libgdal.la && ln -s ../libgdal.la libgdal.la)
make[1]: Leaving directory `/home1/MAPSERVER/SRC/gdal-1.3.1'
(cd swig; make build)
make[1]: Entering directory `/home1/MAPSERVER/SRC/gdal-1.3.1/swig'
for dir in ; do (cd $dir; make build ); done
/bin/sh: syntax error at line 1: `;' unexpected
make[1]: *** [build] Error 2
make[1]: Leaving directory `/home1/MAPSERVER/SRC/gdal-1.3.1/swig'
make: *** [swig-target] Error 2
I use GNU Make 3.80 and GNU ld 2.11.2 under Solaris 8.
I would be glad if somone could tell me something.
Thanks.
Juan M.
Bruce Bill escribió:
> Please post you error message again, including the configure options
> you used. Let's see if we can help you with your problem.
> I 've installed gdal1.3.1 on our solaris, I don't have system admin
> privilege, yet I was able to install it successfully.
> Best,
> */Juan Mari Celihueta <jmcm at euskalnet.net>/* wrote:
> So, nobody had problems compiling gdal 1.3.1 under Solaris 8? Is gdal
> 1.3.1 tested under this platform?
> Regards.
> Juan M.
> Frank Warmerdam escribió:
> >On 11/14/05, Juan Mari Celihueta wrote:
> >>I continue with the same problem. I added the prefix you
> indicated, and
> >>I also tried as root, but I get exactly the same error message.
> >>I hope someone can help me.
> >Juan,
> >It seems you are running into some funky problem with
> >the linker and/or libtool's handling of shared libraries. I
> >have no idea how to fix things.
> >Best regards,
