[Gdal-dev] GMT & GDAL Geotiff grid registration
    jluis
    jluis at ualg.pt
    Fri Nov 18 15:37:29 EST 2005
Frank Warmerdam wrote:
> On 11/18/05, Rich Signell <rsignell at usgs.gov> wrote:
>>In case this is really a missing feature, the PIXEL vs. LINE
>>registration of a GMT file is really easy to check.  You just read
>>the "node_offset" attribute of the grid variable.
>>If node_offset=0, it's LINE
>>If node_offset=1, it's PIXEL
> Rich,
> You are suggesting the node_offset on the "z"
> variable should be examined to determine if the x and
> y locations are relative to the top left corner of the pixel or
> the center?  Why the terminology of "LINE" vs. "PIXEL"?
> If you can provide the file in question, I'll see what I can do.
Frank,
I (re)mentioned this issue 3 days ago. Please revisit bug 796 in Bugzilla
(which is still open)
J. Luis
