[Gdal-dev] Lambert to Swiss Obl projection error?
Jed O. Kaplan
Jed.Kaplan at ips.unibe.ch
Sun Nov 20 09:12:04 EST 2005
Hello all,
I am using the latest CVS versions of GDAL and PROJ4 on Mac OS X 10.4
I am trying to warp a small 100x100 raster in a Lambert Azimuthal
projection to the Swiss Obl. Mercator projection. gdal_warp runs
successfully, but the output raster is wrong - the grid seems shifted
to the north by ca. 20km (a simple shift of the grid does not solve
the problem, however). You can see the problem if you compare the
calculated center lon and lat of the input and output rasters - these
center points should be approximately the same, but are shifted ca.
00:12' to the north in the output grid.
The relevant output from gdalinfo and the gdal_warp command line, as
well as the WKT file I use to define the Swiss projection are copied
below.
Could this be a bug in GDAL, or possibly in PROJ4? Thank you for any
advice you may be able to give me!
Cheers,
Jed Kaplan
jkaplan at kootenay:~/Documents/science_projects/vivaldi/BioClim_SR >
gdalinfo terrain.tif
Driver: GTiff/GeoTIFF
Size is 100, 100
Coordinate System is:
PROJCS["Lambert Azimuthal Equal Area",
GEOGCS["unnamed",
DATUM["unknown",
SPHEROID["unnamed",6370997,0]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Lambert_Azimuthal_Equal_Area"],
PARAMETER["latitude_of_center",46.8],
PARAMETER["longitude_of_center",8.2],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (114914.109000,-17980.043000)
Pixel Size = (250.00000000,-250.00000000)
Metadata:
AREA_OR_POINT=Area
Corner Coordinates:
Upper Left ( 114914.109, -17980.043) ( 9d42'18.00"E, 46d37'42.29"N)
Lower Left ( 114914.109, -42980.043) ( 9d41'55.60"E, 46d24'13.08"N)
Upper Right ( 139914.109, -17980.043) ( 10d 1'56.36"E, 46d37'25.12"N)
Lower Right ( 139914.109, -42980.043) ( 10d 1'29.10"E, 46d23'55.99"N)
Center ( 127414.109, -30480.043) ( 9d51'54.75"E, 46d30'49.54"N)
Band 1 Block=100x20 Type=Float32, ColorInterp=Gray
gdalwarp -t_srs swiss.wkt -rb terrain.tif terrain-sw.tif
Creating output file that is 101P x 101L.
:0...10...20...30...40...50...60...70...80...90...100 - done.
gdalinfo terrain-sw.tif
Size is 101, 101
PROJCS["Swiss. Obl. Mercator",
GEOGCS["bessel",
DATUM["CH1903",
SPHEROID["Bessel 1841",6377397.155,299.1528128000008,
AUTHORITY["EPSG","7004"]],
AUTHORITY["EPSG","6149"]],
PROJECTION["Hotine_Oblique_Mercator"],
PARAMETER["latitude_of_center",46.95240555555556],
PARAMETER["longitude_of_center",7.439583333333333],
PARAMETER["azimuth",90],
PARAMETER["rectified_grid_angle",90],
PARAMETER["scale_factor",1],
PARAMETER["false_easting",600000],
PARAMETER["false_northing",200000],
UNIT["metre",1,
Origin = (772925.084811,188209.083260)
Pixel Size = (249.84685851,-249.84685851)
Metadata:
AREA_OR_POINT=Area
Corner Coordinates:
Upper Left ( 772925.085, 188209.083) ( 9d42'22.99"E, 46d49'25.83"N)
Lower Left ( 772925.085, 162974.551) ( 9d41'48.72"E, 46d35'48.88"N)
Upper Right ( 798159.618, 188209.083) ( 10d 2'13.02"E, 46d49'0.48"N)
Lower Right ( 798159.618, 162974.551) ( 10d 1'33.75"E, 46d35'23.64"N)
Center ( 785542.351, 175591.817) ( 9d51'59.62"E, 46d42'25.14"N)
Band 1 Block=101x20 Type=Float32, ColorInterp=Gray
more swiss.wkt
GEOGCS["bessel",
DATUM["CH1903",
SPHEROID["bessel",6377397.155,299.1528128],
TOWGS84[674.374,15.056,405.346,0,0,0,0]],
UNIT["metre",1]]
