[Gdal-dev] WKB
Bart van den Eijnden
BEN at Syncera-ITSolutions.NL
Mon Nov 21 08:24:28 EST 2005
Hi list,
I have done a bit more analysis but have been unable to solve this unfortunately.
1) creating a view with all the columns does not make a difference, still no geometry is read (only XMIN, XMAX etc.)
2) properly filling the SRS table and column does not make any difference.
I have attached an example BLOB field, maybe somebody could judge from this what is going wrong.
I tried with CPL_DEBUG ON but could not get any useful messages out of ogrinfo. Btw my data is (multi) polygon data.
C:\Programs\FWTools0.9.9>ogrinfo ODBC:synfonie/synfonie at tatukgistest
ODBC: EstablishSession(tatukgistest,synfonie,synfonie)
ODBC: SQLConnect(tatukgistest)
ODBC: GetColumn() - m_nColCount=500
OGR: OGROpen(ODBC:synfonie/synfonie at tatukgistest) succeeded (00825D00).
INFO: Open of `ODBC:synfonie/synfonie at tatukgistest'
using driver `ODBC' successful.
1: BIS_LOC_FEA
ODBC: SQLDisconnect()
C:\Programs\FWTools0.9.9>ogrinfo ODBC:synfonie/synfonie at tatukgistest BIS_LOC_FEA
-summary
OGR: OGROpen(ODBC:synfonie/synfonie at tatukgistest) succeeded (008274E8).
Layer name: BIS_LOC_FEA
Geometry: Unknown (any)
Feature Count: 3444
Layer SRS WKT:
(unknown)
LOC_CODE: String (11.0)
XCOORD: Real (9.0)
YCOORD: Real (9.0)
TAB_LABEL: String (5.0)
ODBC: 6888 features read on layer 'BIS_LOC_FEA'.
Thanks in advance.
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> "Bart van den Eijnden" <BEN at syncera-itsolutions.nl> 11/21/2005 11:21 AM >>>
Okay, I am one step further, it seemed to be caused by the wrong case in the F_TABLE_NAME and G_TABLE_NAME fields.
But now ogrinfo does not report any geometries, it just reports the attributes from the F_TABLE_NAME table.Why is this?
C:\Programs\FWTools0.9.9>ogrinfo ODBC:synfonie/synfonie at tatukgistest BIS_LOC_FEA -summary
Feature Count: 3444
Layer SRS WKT:
(unknown)
XCOORD: Real (9.0)
YCOORD: Real (9.0)
OGRFeature(BIS_LOC_FEA):508
LOC_CODE (String) = AA060700163
XCOORD (Real) = 78898
YCOORD (Real) = 444712
TAB_LABEL (String) = (null)
OGRFeature(BIS_LOC_FEA):509
LOC_CODE (String) = AA060700165
XCOORD (Real) = 78720
YCOORD (Real) = 444737
Best regards,
Bart
Postbus 270
2600 AG DELFT
>>> "Bart van den Eijnden" <BEN at syncera-itsolutions.nl> 11/21/2005 10:43 AM >>>
Hi list,
I am trying to connect OGR through ODBC to a WKB database. The WKB database was created using TatukGIS (www.tatukgis.com).
I am getting the following error back from OGR:
ERROR 1: No column definitions found for table 'bis_loc_FEA', layer not usable.
This is the record in the GEOMETRY_COLUMNS table (in XML format):
<main>
<DATA_RECORD>
<F_TABLE_NAME>bis_loc_FEA</F_TABLE_NAME>
<F_GEOMETRY_COLUMN>GID</F_GEOMETRY_COLUMN>
<G_TABLE_NAME>bis_loc</G_TABLE_NAME>
<STORAGE_TYPE>1</STORAGE_TYPE>
<GEOMETRY_TYPE>11</GEOMETRY_TYPE>
<COORD_DIMENSION>2</COORD_DIMENSION>
<MAX_PPR>0</MAX_PPR>
<SRID>1</SRID>
</DATA_RECORD>
</main>
The tables are defined as:
CREATE TABLE BIS_LOC
GID NUMBER(9) NOT NULL,
XMIN FLOAT(126),
YMIN FLOAT(126),
XMAX FLOAT(126),
YMAX FLOAT(126),
WKB_GEOMETRY BLOB
CREATE TABLE BIS_LOC_FEA
LOC_CODE VARCHAR2(11 BYTE),
XCOORD NUMBER(9),
YCOORD NUMBER(9),
TAB_LABEL VARCHAR2(5 BYTE)
What could be the problem? Thanks in advance. It seems TatukGIS does not write SRS info, but that does not seem to be the cause of the above error.
Best regards,
Bart
Postbus 270
2600 AG DELFT
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051121/b712b1e5/blob.obj
