[Gdal-dev] SDE Implementation
Frank Warmerdam
warmerdam at pobox.com
Fri Nov 25 14:06:00 EST 2005
Howard,
I have now have the essentials of the read-only SDE vector driver
complete. This includes:
o Getting list of layers (tables) from registration info
o Support for the attribute field types supported by mapsde.c,
including date, and blob.
o Support for fast GetFeature() fetching the row by rowid.
o Support for fast spatial extents from layerinfo.
o Support for relatively fast feature counting using a fetch
of only the feature ids.
o Support for fast spatial query using spatial constraints on stream.
o Support for fast attribute filtering using queryinfo where clause.
o Support for reading coordinate system (from layerinfo).
o Support for point, line and polygon geometries (2d or 3d).
o I avoid fetching the layerinfo unless needed. Normally just for
layers that are actively queried rather than all layers in the
datasource.
o Configuration logic on unix (similar to MapServer config options).
Still needed:
o Support for multi-point, multi-line and multi-polygon geometries.
o Support for esoteric field types (XML, etc).
o Logic to pass layers names, shape column, and fid column in the
datasource names.
o Build support on windows.
o Review annotation and "cad' data objects for possible support.
Testing needed:
o With no coordref.
o Odd field types (blob, date, etc).
o Tables with no geometry?
o Tables with multiple geometry columns.
o datasources with no registration info (SDE for Coverages).
o test with 3D layers.
o test with measured layers (measures to be ignored).
All in all the SDE API is pretty straight forward, and this has
been a surprisingly pleasant activity. Of course, in large part
that is due to your providing a setup server, and providing
me with good documentation.
If you are feeling ambitious, feel free to try building and
testing things a bit.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
