[Gdal-dev] missing function to destroy properly OGRStyleTool ?
Fabien Dachicourt support at geoimage.fr
Mon Nov 28 11:05:16 EST 2005
i'm using styles with OGR to display geometries.
for a given feature, i get OGRStyleTool objects from style manager with "GetPart", then i delete them on my own.
My problem is i'm wondering if i can delete on my own these OGRStyleTool while they are created inside a gdal/ogr function (GetPart).
I know that many problems appear when the "new" is done inside gdal/ogr library, whereas the "delete" is done outside (the best example is OGRGeometry for which we have to use OGRGeometryFactory to create and destroy geometries).
My question is : how can i delete properly these OGRStyleTools ?
This is my source code :
poStyleMgr->GetStyleString(poFeature);
   for (int i = 0; i < poStyleMgr->GetPartCount(); i++)
       OGRStyleTool* poStyleTool = poStyleMgr->GetPart(i);
       if (poStyleTool)
            switch(poStyleTool->GetType())
            //process....
            delete poStyleTool;
Thanks in advance,
Fabien
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051128/0a959267/attachment.html
