[Gdal-dev] Geodatabase Driver: Layer type vs layer content
Craig Miller
craig.miller at spatialminds.com
Mon Nov 28 21:41:02 EST 2005
I'm using the Geodatabase driver to import data into PostGIS. I've only
done a few tests, but it appears that the underlying driver always reports a
layer as being a point/line/poly layer even if it also contains multipoint,
multiline, multipoly data. I haven't tried with 2.5D data yet.
Has anyone else seen this?
--Craig
