[Gdal-dev] GDAL changes affecting GRASS?
Wed Nov 30 12:07:28 EST 2005
On 11/30/05, William Kyngesburye <woklist at kyngchaos.com> wrote:
> Looking at the configure logic for geotiff, it seems to be
> backwards.  What I see (generalized, ignoring the internal tests):
> if with=yes [which means look for geotiff in default locations]
>    test for geotiff using the 'with' value for -L + current LIBS
>    (LIBS="-lgeotiff -L$with_geotiff/lib $LIBS)
> else [look for it in user pecified location]
>    test for goetiff using default locations + current LIBS
>    (LIBS="-lgeotiff $LIBS)
William,
I believe you are correct.  Can you turn this into a
proposed patch to fix the problem?
Best regards,
