[Gdal-dev] GDAL 1.3.1 Alpha 2 Released
Martin Spott
Martin.Spott at mgras.net
Sat Oct 1 09:41:50 EDT 2005
Martin Spott wrote:
> I like it, because it compiles on Solaris without hassle - while 1.3.0
> didn't.
Aaaah, wrong, still the same error, apparently I overlooked this.
Please consider this as a simple notice, at the moment I don't have the
time to dig further into it. OGDI-3.1.5 is installed in /opt/GRASS/:
make[3]: Entering directory `/usr/local/src/gdal-1.3.1a2/ogr/ogrsf_frmts/ogdi'
/bin/sh ../../../libtool --mode=compile g++ -mcpu=hypersparc -mtune=hypersparc -Wall -O3 -I.. -I../.. -I/opt/GRASS -I/opt/GRASS/include -I/opt/gnu/include -I/usr/local/include -I../../../port -c -o ../o/ogrogdidriver.o ogrogdidriver.cpp
g++ -mcpu=hypersparc -mtune=hypersparc -Wall -O3 -I.. -I../.. -I/opt/GRASS -I/opt/GRASS/include -I/opt/gnu/include -I/usr/local/include -I../../../port -c ogrogdidriver.cpp -o ../o/ogrogdidriver.o
In file included from ../../ogr_spatialref.h:102,
from ../../ogr_geometry.h:210,
from ../../ogr_feature.h:131,
from ../ogrsf_frmts.h:196,
from ogrogdi.h:63,
from ogrogdidriver.cpp:46:
../../ogr_srs_api.h:384: error: `CPL_STDCALL' does not name a type
../../ogr_srs_api.h:385: error: `CPL_STDCALL' does not name a type
../../ogr_srs_api.h:386: error: `CPL_STDCALL' does not name a type
../../ogr_srs_api.h:387: error: `CPL_STDCALL' does not name a type
../../ogr_srs_api.h:398: error: `CPL_STDCALL' does not name a type
../../ogr_srs_api.h:409: error: `CPL_STDCALL' does not name a type
../../ogr_srs_api.h:410: error: `CPL_STDCALL' does not name a type
../../ogr_srs_api.h:411: error: `CPL_STDCALL' does not name a type
../../ogr_srs_api.h:421: error: `CPL_STDCALL' does not name a type
../../ogr_srs_api.h:424: error: expected init-declarator before "OSRGetAttrValue"
../../ogr_srs_api.h:424: error: expected `,' or `;' before "OSRGetAttrValue"
../../ogr_srs_api.h:444: error: `CPL_STDCALL' does not name a type
../../ogr_srs_api.h:679: error: `CPL_STDCALL' does not name a type
../../ogr_srs_api.h:682: error: `CPL_STDCALL' does not name a type
../../ogr_srs_api.h:685: error: `CPL_STDCALL' does not name a type
../../ogr_srs_api.h:689: error: `CPL_STDCALL' does not name a type
make[3]: *** [../o/ogrogdidriver.o] Error 1
/bin/sh ../../../libtool --mode=compile g++ -mcpu=hypersparc -mtune=hypersparc -Wall -O3 -I.. -I../.. -I/opt/GRASS -I/opt/GRASS/include -I/opt/gnu/include -I/usr/local/include -I../../../port -c -o ../o/ogrogdidatasource.o ogrogdidatasource.cpp
g++ -mcpu=hypersparc -mtune=hypersparc -Wall -O3 -I.. -I../.. -I/opt/GRASS -I/opt/GRASS/include -I/opt/gnu/include -I/usr/local/include -I../../../port -c ogrogdidatasource.cpp -o ../o/ogrogdidatasource.o
from ogrogdi.h:63,
from ogrogdidatasource.cpp:61:
make[3]: *** [../o/ogrogdidatasource.o] Error 1
/bin/sh ../../../libtool --mode=compile g++ -mcpu=hypersparc -mtune=hypersparc -Wall -O3 -I.. -I../.. -I/opt/GRASS -I/opt/GRASS/include -I/opt/gnu/include -I/usr/local/include -I../../../port -c -o ../o/ogrogdilayer.o ogrogdilayer.cpp
g++ -mcpu=hypersparc -mtune=hypersparc -Wall -O3 -I.. -I../.. -I/opt/GRASS -I/opt/GRASS/include -I/opt/gnu/include -I/usr/local/include -I../../../port -c ogrogdilayer.cpp -o ../o/ogrogdilayer.o
from ogrogdi.h:63,
from ogrogdilayer.cpp:73:
make[3]: *** [../o/ogrogdilayer.o] Error 1
make[3]: Target `default' not remade because of errors.
make[3]: Leaving directory `/usr/local/src/gdal-1.3.1a2/ogr/ogrsf_frmts/ogdi'
make[2]: *** [ogdi-target] Error 2
Cheers,
Marttin.
Unix _IS_ user friendly - it's just selective about who its friends are !
