[Gdal-dev] GDAL 1.3.1 Alpha 2 Released
Thom DeCarlo t.r.decarlo at larc.nasa.gov
Mon Oct 3 15:15:37 EDT 2005
> -----Original Message-----
> From: Frank Warmerdam
> Sent: Monday, October 03, 2005 2:59 PM
> To: Thom DeCarlo
> Cc: GDAL-dev
> Subject: Re: [Gdal-dev] GDAL 1.3.1 Alpha 2 Released
> On 10/3/05, Thom DeCarlo <t.r.decarlo at larc.nasa.gov> wrote:
> > It looks like the cygwin build is broken in the 1.3.2 alpha2 release. I
> > downloaded a fresh update of Cygwin, but specified the gcc 3.3.3
> compiler
> > (OpenSceneGraph won't compile with the Cygwin version of g++ 3.4.x). Did
> a
> > ./configure and make with these results:
> > /bin/sh.exe ../libtool --mode=compile g++ -Wall  -O2   -I../port  -c -o
> > cpl_vsil.o cpl_vsil.cpp
> >  g++ -Wall -O2 -I../port -c cpl_vsil.cpp  -DPIC -o .libs/cpl_vsil.o
> > cpl_vsil.cpp: In function `int VSIFFlush(FILE*)':
> > cpl_vsil.cpp:167: error: new declaration `int VSIFFlush(FILE*)'
> > cpl_vsi.h:156: error: ambiguates old declaration `void VSIFFlush(FILE*)'
> > make[1]: *** [cpl_vsil.o] Error 1
> > make[1]: Leaving directory `/cygdrive/c/Svs_dev_C/gdal-1.3.1a2/port'
> > make: *** [port-target] Error 2
> > It will be a little while before I have time to dig into this. Maybe the
> > problem will be obvious to someone else, though.
> Thom,
> I have fixed this.  It was related to my changes to virtualize IO, and
> the fact that Cygwin did not (as configure treats it) support the large
> file API.  My fix is to ensure that the "large file API" is always built
> even if it is essentially just a small file API that supports
> virtualization.
> This means that Cygwin builds of GDAL still lack large file support,
> though looking at cygwin man pages I think this too could be corrected
> if necessary.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
Frank,
Thanks for the update. That sounds good enough for me.
Thom
Thom DeCarlo
      Given sufficient time and money, all things are possible.
  In lieu of time and money, caffeine and aspirin may also work.
