[Gdal-dev] Oracle locator/spatial bindings w/ ogr
Frank Warmerdam
warmerdam at pobox.com
Tue Oct 4 09:22:06 EDT 2005
On 10/4/05, Stephan Holl <sholl at gmx.net> wrote:
> Dear GDAL/OGR-users,
> I am trying to build the latest CVS-sources with oci-bindings. During the
> configure-process everything works fine (oci is set tu yes). But when I try
> $GDAL/ogr/.libs/ogrinfo --formts no OCI-format is supported.
> Do I have to do a ' make install' in order to recognize the new
> oci-bindings?
Stephan,
I would suggest a "make clean ; make" to ensure that all the correct
files were re-compiled when you added in OCI support. I don't know
how you have your shared library searching setup but it does seem
likely that you are picking up an old libgdal.so in /usr/local/lib so
I would suggest installing and then trying again.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
