[Gdal-dev] compile error GDAL 1.3.0 [solved]
Dylan Beaudette dylan at iici.no-ip.org
Thu Oct 6 14:08:08 EDT 2005
On Thursday 06 October 2005 09:52 am, Dylan Beaudette wrote:
> On Thursday 06 October 2005 07:19 am, Frank Warmerdam wrote:
> > On 10/5/05, Dylan Beaudette <dylan at iici.no-ip.org> wrote:
> > > I get the error:
> > > gcore/gdal_misc.cpp:1308: error: `OGRSpatialReference' undeclared
> > > (first use this function)
> > > gcore/gdal_misc.cpp:1308: error: (Each undeclared identifier is
> > > reported only once for each function it appears in.)
> > > gcore/gdal_misc.cpp:1308: error: syntax error before `,' token
> > > gcore/gdal_misc.cpp:1311: error: `oSRS' undeclared (first use this
> > > function) gcore/gdal_misc.cpp:1312: error: `oSRSGeogCS' undeclared
> > > any ideas ?
> > Dylan,
> > That is very stange.  gdal_misc.cpp 1.70 (in GDAL 1.3.0) includes
> > ogr_spatialref.h which includes the OGRSpatialReference declaration.
> > I don't see how OGRSpatialReference could be not defined in
> > gdal_misc.cpp.  You might want to check if there is a truncated
> > ogr_spatialref.h sitting around in /usr/local/include or the local
> > build for some reason.
> > You might also want to work from 1.3.1 if you are setting up a new
> > system.
> > Best regards,
> Thanks for the quick reply Frank.
> Just to verify that ogr_spatialref.h was defined in gdal_misc.cpp, i tried:
> dylan at test:~/src/gdal-1.3.1$ grep
> ogr_spatialref.h /home/dylan/src/gdal-1.3.1/gcore/gdal_misc.cpp
> #include "ogr_spatialref.h"
> ...looks fine there...
> However, GDAL 1.3.1 dies with the same error during make. I have tried to
> compile with a slightly different .configure step:
> ./configure --with-png=internal --with-jpeg=internal \
> --with-gif=internal --with-libtiff=internal \
> --with-geotiff=internal --with-libz=internal\
> --without-pg --without-ogdi
> ... but i still get the same error.
> of note the compiler is gcc-3.3.6
> any ideas?
> thanks!!
> Dylan
Black eye for me... Looks like i had this in my configure args:
--with-libz=internal--without-pg
missing a space!!
thanks Frank for replying to my previous email
Cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
