[Gdal-dev] OGR's importFromEPSG depends on libgeotiff?
Frank Warmerdam
warmerdam at pobox.com
Thu Oct 6 23:08:05 EDT 2005
On 10/6/05, Ben Discoe <ben at vterrain.org> wrote:
> Hi folks,
> One small observation and a question..
> The documentation for OGRSpatialReference::importFromEPSG says:
> "This code uses the GeoTIFF cpl_csv services to access the EPSG CSV
> data. If frmts/gtiff/libgeotiff isn't linked in, linking will fail."
> This sounds like it might be out of date; isn't the cpl_csv quite a core
> component of GDAL/OGR nowadays...
Ben,
The comment is a bit inaccurate. The importFromEPSG() method actually
depends on the functions in libgeotiff that are built on top of the cpl_csv
services.
> The question is, what method provides the inverse of importFromEPSG(). That
> is, given a common CRS in an OGRSpatialReference, can it return an EPSG
> coordinate system code, which when later passed to importFromEPSG(),
> re-constructs that same CRS?
Unfortunately this direction does not exist currently as a method
on the OGRSpatialReference. In libgeotiff there is a function
GTIFMapSysToPCS() that does that a bit for some simple cases.
#define MapSys_UTM_North -9001
#define MapSys_UTM_South -9002
#define MapSys_State_Plane_27 -9003
#define MapSys_State_Plane_83 -9004
int CPL_DLL GTIFMapSysToPCS( int MapSys, int Datum, int nZone );
But it only works for a few common hardcoded cases (ie. UTM WGS84).
It has been an ambition of mine to some day build such a thing.
Note that some WKT coordinate system definitions include the PCS
(EPSG) code which can be extracted with the authority related
methods.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
