[Gdal-dev] Re: A list of things in the wrappers and geom type in ogr
Charlie Savage cfis at interserv.com
Mon Oct 10 14:03:46 EDT 2005
Hi Ari,
> I tried the unsupported error and it lead me to noticing that the
> wrappers use throw but do not catch. Don't we need something like
> try{
>    result = (OGRErr)OGRFeatureShadow_SetGeometry(arg1,arg2);
> catch (int e) {
>    SWIG_exception( SWIG_RuntimeError, OGRErrMessages(e) );
The OGR c api returns error codes instead of throwing exceptions.   So
there isn't a need for catch.  Thus the generated code should look
something like this:
    CPLErrorReset();
    CPLErr eclass = CPLGetLastErrorType();
    if ( eclass == CE_Failure || eclass == CE_Fatal ) {
       SWIG_exception( SWIG_RuntimeError, CPLGetLastErrorMsg() );
> Still one more thing, null pointers and wrapper functions. Is the plan
> to test for inappropriate null pointers in the wrapper functions, or do
> we write the checks into typemaps? Now the situation is still that it is
> far too easy to create a segfault with undefined script variables thrown
> at methods.
What do you mean by a null pointer?  Do you mean passing a null object
in the target language to OGR?  Do you have an example you could share?
Thanks,
Charlie
