[Gdal-dev] rough patch for gdal to get GCP information from .NOS
files
Karl P
karl at tweak.net.au
Thu Oct 13 09:59:27 EDT 2005
Attached is a diff against 1.3.1, that adds support for gdal to get the GCP information
from the .GEO files that accompany a .NOS file.
.NOS files are just like BSB files, except that instead of having a plain text header
section containging projection and control point information, it comes in a corresponding
.geo file.
The patch is pretty dirty, (gdalinfo will print out the correct information, and then
segfault) mostly because I'm using the "wrong" tools to do the string manipulation.
Cheers,
Karl P
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051013/0b0012e8/nosgeohack.bin
