[Gdal-dev] Vertical geoidal/ellipsoidal conversion
Robert Waterman
rwaterman at digitalglobe.com
Thu Oct 20 10:47:26 EDT 2005
I need to do some vertical datum conversions. Given a single X,Y,Z
point I need to be able to convert Z between ellipsoidal and geoidal
heights. Can someone point me in the right direction for doing such
conversions? I am working in Python and found the class
CoordinateTransformation in osr.py under FWTools0.9.8. If this will do
what I want, can someone provide an example of how I would actually do
this? Thanks for your time.
Regards,
Rob
Robert T. Waterman
Digital Mapping Analyst II
DigitalGlobe(r)
(303) 684-4330
www.digitalglobe.com <http://www.digitalglobe.com/>
The information contained in this message is intended only for the
person or entity to which it is addressed. It may contain DIGITALGLOBE
Proprietary or Confidential material. Any review, retransmission,
dissemination or other use of this information by persons or entities
other than the intended recipient is prohibited. If you received this
message in error, please contact the sender and delete or destroy this
message. Thank you.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051020/c37092cb/attachment.html
