[Gdal-dev] Warping from a full disk image of the Earth
Frank Warmerdam
warmerdam at pobox.com
Fri Oct 21 17:30:22 EDT 2005
On 10/21/05, Paul Xander <paul at qwikcast.com> wrote:
> Hi,
> I've been trying to determine if 'gdalwarp' is the tool for
> reprojecting a section of a jpeg full disk image of the earth into a
> standard format such as Lambert Equal Area.
Paul,
Yes, gdalwarp can do this assuming you have appropriate georeferencing
for the image. If the image has a world file providing the coordinates,
you can supply the coordinate system with the -s_srs switch.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
